Using a Hands-On Lab
Follow these steps to effectively use a hands-on lab:
  1. Log in to the User Portal:
    • Access the learning platform and sign in with your credentials.
  2. Navigate to the Course:
    • Open the course that includes the lab you want to use.
    • Labs are typically located after specific video lessons in the course content.
  3. Access the Lab Section:
    • Find the lab in the course module.
    • Click on the lab to view its details.
  4. Review the Lab Overview and Rules:
    • Read the Overview to understand the objectives of the lab.
    • Go through the Instructions carefully to familiarize yourself with the tasks.
    • Note the Prohibited Activities to ensure compliance with platform guidelines.
  5. Start the Lab:
    • Click the Start Lab button to initiate the lab environment.
    • A timer will start, indicating the duration available for the lab.
  6. Access the Lab Environment:
    • Click the Access Lab button to enter the interactive lab environment.
    • Follow the on-screen instructions to begin the tasks.
  7. Work Through the Lab Tasks:
    • Complete the tasks as per the instructions provided.
    • Use the pre-configured tools, environments, and resources in the lab.
  8. Monitor Your Time:
    • Keep an eye on the timer to ensure you complete the lab within the allocated time.
  9. End the Lab:
    • Once you finish, click the End Lab button to exit.
    • Ensure all progress is saved, if applicable.
Key Features of the Lab
  • Timer: Tracks how much time is remaining for the session.
  • Preconfigured Environment: Includes tools and configurations needed for completing the tasks.
  • Guided Instructions: Provides step-by-step guidance for lab activities.
  • End Lab Button: Use this to close the lab and save your progress.
Tips for Using Hands-On Labs
  • Understand Objectives: Clearly review the lab goals before starting.
  • Follow Instructions Carefully: Avoid skipping steps to ensure successful task completion.
  • Utilize the Environment: Make the most of the tools and settings provided in the lab.
  • Document Your Work: Take notes to record key learnings and results.
  • Manage Time Wisely: Use the timer to pace your progress effectively.
    • Starting a Hands-On Lab
      Follow these steps to start a hands-on lab: Log in to the User Portal: Sign in using your credentials on the learning platform. Navigate to the Course: Open the course that contains the lab you want to complete. Labs are typically available after ...
    • Using a Playground
      Step 1: Navigate to the Playgrounds Look for the Left Menu on your platform/dashboard interface. Click on the option labeled "Playgrounds". This will open a section containing a list of available playgrounds. Step 2: Select a Playground Browse ...
    • Using the Organization Dashboard
      Follow these steps to navigate and utilize the Organization Dashboard: Log in to the Admin Dashboard: Navigate to the Admin section using the sidebar menu. Access the Organization Dashboard: Click on Organization under the Admin menu to access the ...
    • Where Are My Running Labs?
      Follow these steps to locate and manage your running labs: Access the Side Panel: Log in to the platform and navigate to the Side Panel on the dashboard. Find Running Labs: Click on Running Labs in the side panel to view all active labs. Choose a ...
    • Start a Course
      Follow these steps to start a course: Log in to the User Portal: Access your learning platform and sign in using your credentials. Access the Courses Section: Navigate to Courses in the sidebar menu to view your available courses. Select a Course: ...
