Related Articles
Find a playground
Follow the steps below to efficiently search using filters: Access the Playground Navigate to the left menu bar. Click on the Playground option to open the search interface. Search Using Filters Learning Path Filter: Select the Learning Path filter ...
Find an already started playground
Navigating to Playground Step 1: Select the Playground Option In the left menu bar, look for an option labeled "Playground". Click on the Playground option to access it. Step 2: Search Within the Progress Status If the Playground is already started: ...
Using the Organization Dashboard
Follow these steps to navigate and utilize the Organization Dashboard: Log in to the Admin Dashboard: Navigate to the Admin section using the sidebar menu. Access the Organization Dashboard: Click on Organization under the Admin menu to access the ...
Using a Hands-On Lab
Follow these steps to effectively use a hands-on lab: Log in to the User Portal: Access the learning platform and sign in with your credentials. Navigate to the Course: Open the course that includes the lab you want to use. Labs are typically located ...
Create a Favorites List
Follow these steps to create a favorites list: Log in to the User Portal: Access your learning platform and sign in using your credentials. Navigate to the Desired Course or Resource: Browse the catalog or use the search bar to find the course, ...
